leak fix
Bozeman, MT
So I have noticed every time I park my cruiser in the garage that a puddle of axle fluid builds up in my floor at the front of the third member. From looking at it, it seems that the fluid is leaking from right behind where the driveshaft connects. Could this be the pinion seal? If not what could it be? Do I need to pull out the diff and ring and pinion or is there an easier way to fix it?
If you mean 'where the driveshaft connects' instead of 'where the axle connects' then I would wager that your guess of pinion seal is correct.
In my case I have had small/slow leaks there that were really only evident when I pulled off the driveshaft flange from the pinion flange. I 'cured' those by filling the cavity around the pinion nut with RTV, after a thorough cleaning out with brake cleaner.
I have, long ago, replaced a pinion seal and worn out shims, in the rear, while under the vehicle. I'm not sure this was all done in the best manner possible, so I'm not sure I should advise this route to you. Later on, when doing a locker install, I did replace the pinion flange and seals, etc. on the bench, and I was able to check the preload, etc. per the factory service manual and felt the repair was done more closely to 'the correct method'
Yeah thats what I meant Dave a little mistype on my part. Did this fix take a fair amount of time and work? Would it be possible to fix it pretty easily under the cruiser or would it be better to just remove it all from under the cruiser. I am about to take out the diff to weld it is there a way I can seal it then or just slow the leak in some way? I know I'm spitting out a lot of questions any help is greatly appreciated. Thanks
Change the seal first and see what happens. Only took about 15 min. Be sure to stake the nut when you re-install.
