Leak Down Test
Buffalo, Wyoming
Could someone explain the theory and proceedure for a leak down test. I am having some fuel mixture problems and need to do some diognosis for Mark before I send him my carb. I am going to do a compression test tomorrow and maybe a leak down test if I think I need it. I am just trying to get prepared. Thanks!
A leak down test is verifying if you have a leakage in compression from air escaping into the manifolds from the valve or valve seats being damaged, or air escaping into the crankcase from poor rings. You make sure that both valves are closed and then pressurize the cylinder with air through the spark plug hole.
oil consumption, blow-by, poor performance, over heating, loss of coolant, or piece of mind....??
I dont think I really have any of those problems. Not very good vacuum 15 @ 650rpm and carb is running very rich. Mark built me a carb and we think it needs a smaller than normal jet. He just wants me to make sure there are no other issues before the jet is replaced and am building by brain power.
What indications of other things would make me want to do a leak down test. Does that make sense?
What do you have going on that makes you think that you need to do one? :rolleyes:
(don'tcha hate the guy that answers a question with a question?) :mad:
When was the last time the valves were adjusted?
When was the last time you had a vacuum gauge hooked up and what was it telling you?
What are/were the condition of your ignition components when removed/inspected/replaced?
What condition is the PCV valve in?
Have you looked for any vacuum leaks in the system?
Really,
What is going on with your truck that makes you think that something is up with your engine internally?
How about the guy who answers a question with SEVEN questions!:D
Ed
I dont know:D
Really,
Valves were adjusted today.
An indash and an in engine copartment vacuum guage were used today and about the best reading I got was 15 @ 650rmp.
I just installed a new pertronix Ignitor II and coil (several days ago).
pcv valve is not stuck and appears functional
I have tried to find any vavuum leaks with no luck.
The only thing I know thats not working is that I have screwed the idle mixture all the way in and that is the best the engine runs and its still too rich and giving off some black smoke and all the plugs are black fowled.
Mark thinks a jet it too big but wants me to check everything else before I send him the carb to which I agree. I am just looking for options on diognosis to make sure I am not missing something and its not the carb. Or maybe I have something wrong along with the carb.:lol:
How this got started, I was reading up on compression, vacuum, etc. and got link over to leak downs and wet down (or whatever it was) and I ended up with more questions than answers.:o
So, what is the jet size in question?
