leak behind heat shield
Saratoga Lake, NY
I spotted a leak or drain from a rubber grommet behind the heat shield right over the top of the y pipe ( pass.side exhaust pipe). It comes out, down the frame and drips from the torsion bar area, so I thought it was the rear exposed heater hoses. The liquid is clear so I assume its water/condensation from the A/C? This started happening a little while ago, and leaves a pretty sizable puddle in the garage.
I had the condenser replaced last fall. A/C is cold.
Is this liquid run off the norm?
Ok thought as much. Pretty big puddle though.
The more humid the air is, the more moisture will get pulled out of the air and drain out from that area. Some low humidity places like the Southwest see very little drainage from that area, if any. As was mentioned - that's normal.
You should see it here, I always get a BIG puddle.:cheers:
