You can remove the compressor from the engine by accessing it through the driver wheel will (remove the wheel/tire obviously). There are two studs and two bolts, and then the high and low side hoses. However, for the 200 series, I don’t remember if you can sneak it out between the body and frame rail and upper control arm. If that’s not possible, you’ll have to remove the oil filter housing/cooler and pull it out through the bottom between the swaybar and crossmember (where you took your photo).good day all.
Has anyone managed to remove their aircon compression on a 200 V8 5.7 and loved to tell the story?
Any decent video one can share?!
Helppp. please…
Thx!You can remove the compressor from the engine by accessing it through the driver wheel will (remove the wheel/tire obviously). There are two studs and two bolts, and then the high and low side hoses. However, for the 200 series, I don’t remember if you can sneak it out between the body and frame rail and upper control arm. If that’s not possible, you’ll have to remove the oil filter housing/cooler and pull it out through the bottom between the swaybar and crossmember (where you took your photo).
