LC200 2008
Hi
i have a LC200 year 2008 and i would like to change the head lights to 2013 model is this possible
Have you considered maybe just clearing up your old headlights?
I was amazed how nice my 2008 lights looked after I got rid of the haze and cloudiness in the covers...
Before:
After:
Before:
After:
Dang Mark! That looks great. Do you have those little microcracks in yours, or just cloudiness? Mine looks like broken-ish glass on the tops. What did you use to clear those up?
The top section on the side, above the yellow reflector have tiny cracks inside, but I'm not going to worry about those. I'm extremely happy with the improvement. I'll be spraying it with a clear coat next week that should add UV protection.
I cleared it up using 15 $15 kit from Harbor Freight that comes with various grit sand paper disks for use on a drill.
My only advice there is to do ALL levels of the paper WET. Simply have a spray bottle of water as you go, keeping the paper and surface WET throughout the process. It is far easier to do, because the sand paper stays clear that way. Other than that, just be sure to use the masking tape around the edge so you don't scratch paint, etc. Really a pretty straight-forward process simply following included directions.
Hi
have a Land Cruiser 200 yr 2008 , I am getting this engine sound on the left hand side
Its just the tap tap sound at 1,500rpm at 50km/hour that increases with revs until the road noise takes over.
Exhaust leak perhaps?
have checked full exhaust system all clear , LC was parked for two months before i brought it has done 140k should i get the injected cleared
any record of maintenance history
