Hi all,
I’ve been lurking for a while and finally need some advice from the brains trust.
Vehicle is a 2008 LC200, currently around 300,000 km. At 300k the engine was fully overhauled. Work done included:
After the rebuild, the vehicle started easily and ran very well. Performance has been strong — it accelerates hard and comfortably reaches 160–180 km/h.
I have a ProVent catch can installed (fitted around 260,000 km). Lately I’m seeing significant oil collection, roughly 100 ml per 1,000 km. The can is drained regularly, but I haven’t replaced the filter element — I’ve only cleaned it with fuel and compressed air.
Turbo issues
Since the rebuild, I’ve had repeated turbo failures on the passenger side:
Interestingly, when each turbo was first installed, there was very little visible smoke at the oil filler cap — however, once the oil cap was tightened, it required pliers to remove, suggesting crankcase pressure.
The vehicle ran exceptionally smoothly with the Chinese turbo initially, then suddenly failed.
The car is currently parked.
Questions
Before spending money on a brand-new genuine turbo, I’d like to rule out any underlying issue:
Any insights, diagnostic steps, or things to check before replacing another turbo would be greatly appreciated.
Thanks in advance.
- New pistons and rings
- New bearings
- New oil pump
- New timing chains
- New lash adjusters
Turbo issues
- First rebuild: seals replaced — failed within a month
- Second rebuild: bearings replaced — failed within a month
- Installed a cheap Chinese turbo as a test (before spending on genuine) — failed within a week
Questions
- What could be causing excessive blow-by / pressure at the oil cap?
- Why do the turbos keep failing — poor rebuilds, or something else?
- Could crankcase pressure be pushing oil through the turbo and killing it?
- Why would oil be present around small hoses and clamps near the turbo?
- Why did the Chinese turbo run perfectly at first, then fail so quickly?
Thanks in advance.
