LC100.. 03-05 17" wheels on LC200 08-11. Will they fit?
Which 17" wheels? The answer is generally yes, the bolt pattern and offset requirements are generally the same between the 100 and 200, as is the center hub diameter. The center caps on the pre-facelift (pre 2016) 200s have a little higher dome, but they don't stick out as far as the front hubs on a 100, so you should be good there.
There is rumor that some 17" rims may not clear the brakes on the 200, but I've yet to see one that actually doesn't clear. You'll have slightly more clearance than later 200s with the smaller brakes on the earlier models.
Thanks! I will try one on and report back.
