LC springs lift - will this color code work?
Arizona
Website
www.jamiebrooks.com
Will This color code combo work correctly to lift my 98 4runner 4x4. I am familiar with the double pink/blue/white spring but not sure about the double pink/RED/white one. Did a bit of searching, no luck about the color code there.
looking for bout 3" of lift for rear.
Those should give you about 3 or 3.5" of lift....see below info from T4R.ORG:
The FJ80 Landcruiser Spring
a cheap effective way to achieve a good amount of lift and flex is to install FRONT springs from a FJ80 (1991-1997) Landcruiser in the REAR of the 3rd gen. there are many different versions of these springs but that main way to identify them is to count how many wraps they have which generally will determine how much lift you will get. you can usually pick up a pair of these for under $100 at a junkyard or on a forum classified section.
  • 7 wrap is about 3-3.5" of lift
  • 8 is about 4"
  • 9 is about 5"
Height of spring/color code/wraps
  • 21" Blue Pink White 9.25 wraps
  • 21" Grey Orange White 9.25 wraps
  • 20.25" Blue Yellow White 8.75 wraps-one of these is a confirmed LX450
  • 19.5" Green Yellow White 8.25 wraps-one of these is a confirmed LX450
  • 19.5" Purple Green White 8 wraps
  • 19.25" Double Purple Dark Blue White 8 wraps
  • 19" Double Pink Light Blue White 7.5 wraps
  • 18.5" Double Pink Grey White 7.5 wraps
  • 18 7/8" Orange Orange White 7.75 wraps
you can also use the OME 851, which is a lift spring for the FJ80. that usually gives about 6 inches of lift.
You'll want to ensure that the taller coil of the 2 goes on the side of the truck that has the gas tank. Otherwise, the truck will be shorter on one side......Hope this helps!
