LC running rough on start....
NW
She sat for a couple of weeks. However, she started right up, but ran rough. I mean really rough. However, as she warms up she runs better but around 1500 rpm there is a hesitation or a miss. I had a recent tune-up [summer]. I am thinking my exhaust manifold crack has caught up with me given that when it warms up it runs better. Any thoughts? TIA!:cheers:
:cool: Hey man, whats up
Possible injector acting up? Maybe have someone stick the tailpipe with an emissions machine and see if youre running rich....just a thought :wrench:.
I'm trying to visualize how a cracked exhaust man would make it rough running and I can't. Help?
Did you check for animals building nests in the inner fender intake? Or mouse/rat damage in wiring looms? How about the rubber intake hose cracking on the bottom from people yanking up on the air cleaner lid with it still attached? If no to both of those, I'd fill it with premium gas to see if it was a fuel issue. Next, I'd be wondering if the fuel pump is the issue or the filter.
DougM
Hopefully not any coolant loaded up in #6 cylinder overnight from a headgasket....
Hey 1shot1kill,
Hate to say it but this way the 1st problem I had before a head gasket was finally the culprit. Murf and I a tearing it down right now.
The HG leaks at piston #6 and the coolant collects in the piston head, rough idle until the coolant burns off.
There are allot of shops that will test you oil for Coolant.
Greg
Thanks! No oil in the coolant! HG...oh boy! :crybaby: I hope not...
:cheers:Okay, I finally had a chance to work on the LC. It was the number 6 plug. It was cracked. Changed her out and she is running smooth once again! :cheers:
It was an insulator tip!:)
An early Christmas present !:clap:
And, Thank God it was only the insulator porcelain tip and not the metal resistor. :cheers: Had it been the metal piece I would have had to miss Christmas for a couple of years.......
