- Joined
- Feb 24, 2010
- Threads
- 2,226
- Messages
- 2,226
Larson Electronics, a leading industrial lighting company, releases an ultra-compact LED spotlight that produces a 2,750 lumen light output with low voltage and amp draw, offers a 50,000 hour service life, and 12 to 32 volt compatibility.
The LED25WRE-CPR high intensity LED spotlight from Larson Electronics is constructed with a single twenty-five watt CREE LED that produces 2,750 lumens of intense light. It is combined with a high output reflector to produce a narrow 10° spread spot beam approximately 1,000’ long. This spot light is built for durability and versatility, with a low profile design, low power requirements, and versatile mounting options within an impact resistant housing. The four and a half inch diameter lamp and reflector assembly is protected by a polycarbonate lens, sealed against water and dust to provide an IP68 rating and weatherproof protection. The LED25WRE-CPR is waterproof to three meters, sealed against intrusion by dust and dirt and very ruggedly constructed to withstand the most demanding environments, conditions and applications.
This spotlight operates on current ranging from 12 to 32 volts DC without any modifications necessary as a result. This unit is able to monitor and adjust input current to maintain the correct LED voltage level regardless of input levels across a specific range. This light is suspended within a form fitting trunnion mount. The trunnion mount has two knurled knobs that can be loosened, allowing the LED light to be adjusted and then retightened to lock the light into any desired position once mounted. A single stainless steel stud protrudes from the bottom of the mount, enabling the operator to install the light using a simple through-hole mount.
“The beam on this ultra-compact LED spotlight is very effective to the far end of its reach at 1,000 feet and has low power requirements when compared to standard one hundred watt halogen lamps,” said Rob Bresnahan, CEO of Larson Electronics. “With its compact housing and sleek appearance, this spot light will look great on any boat or vehicle where low voltage operation is required.”
Larson Electronics carries an extensive line of LED light towers, portable power distribution systems, explosion proof lights for hazardous locations, portable work lights and industrial grade LED area lights. You can view Larson Electronics’ entire line of lighting by visiting them on the web at Larsonelectronics.com. You can also call 1-800-369-6671 to learn more or call 1-903-498-3363 for international inquiries.
The post Larson Electronics Releases a New High Intensity 25 Watt LED Spotlight appeared first on RockCrawler 4x4 and Offroad Magazine.
Related posts:
Continue reading...
Related posts:
- New 25 Watt Bar Clamp Mounted LED Spotlight Released by Larson Electronics
- 90 Watt High Intensity LED Light Bar from Larson Electronics Provides Impressive Performance
- New Bar Clamp Mounted LED Spotlight Released by Larson Electronics
Continue reading...
