I have an engine oil leak at the power steering pump and need to replace the large o-ring on the front of the pump.
My question is, do you have to disconnect the pressure and return lines on the pump in order to access the o-ring? With the two mounting nuts removed, is there enough slack in the lines to pull the pump out far enough to get at the o-ring?
I know the book says disconnect them, but I'm hoping to get around the mess disconnecting them will cause.
Thanks in advance.
Wayne S
Thanks in advance.
Wayne S
