LandTank Caster Plates Installed
Pennsyltucky
Thought I'd get up a quick post with the before and after stats of my truck now that I'm done installing LandTank's Caster Plates.
First off, some history:
Bought the truck in January with OME Heavy/Heavy lift and OME CC bushings installed. With this lift and correction, the caster was out of spec and I could notice it at highway speeds. I had to pay way too much attention to where the truck was going all the time. At that point, the caster was:
Left Front:
Camber--0.2*
Caster--0.6*
Toe--0.02"
Right Front:
Camber--0.2*
Caster--0.0*
Toe--0.01"
Front:
Cross Camber--0.0*
Cross Caster--0.6*
Total Toe--0.04"
Left Rear:
Camber-- -0.2*
Toe-- 0.16"
Rigth Rear:
Camber-- -0.3*
Toe-- -0.05"
Rear:
Total Toe-- 0.12"
Thrust Angle-- 0.21*
Dang. So I wanted to correct but had the feeling that Slee bushings wouldn't get me where I needed to be. After reading and looking and thinking and obsessing, I talked to Landtank about his plates and decided they were probably the best route for me to go.
So, the first thing I had to do was get new OEM control arm bushings and swap out the yellow OME CC bushings and get an alignment so we had a starting point. With the stock bushings in, the caster was BAD!
Left Caster: -0.3*
Right Caster: -1.1*
More discussions with Rick resulted in deciding to go a full 7* of correction with his plates, reasoning the actual gain would fall a couple degrees short of that. Rick piloted the plates and sent me the install kit and drill bit kit in a neat little package.
After work getting in the way too much, I finally worked through the install, finding in the process that the DeWalt right-angle drill is too large for this application. The Milwaukee is definitely preferred. I also used a right-angle air drill that worked well--very small, light, and worked well on the holes up to the last 5/8" bit. The air drill was a 3/8" chuck size and I did not have a 5/8" bit with a 3/8" shank. Had to stop frequently with this one to make sure there was plenty of oil on the bit and in the hole.
Even after all that, I managed to get a hole or two off center through the process (d'oh!) but was able to finagle things with a carbide die-cutter head to shape the holes where necessary. Got the arms remounted and headed in for yet another alignment. Actually, I got two and plan to go to a second shop to check the results. The first alignment resulted in an adjustment to my steering wheel center that made the steering wheel sit cocked left when heading straight. So I doubt the setup on that one. The second was when the same shop corrected the steering center issue and the alignment resulted in different numbers than the first!
Latest alignment caster numbers:
Left: 3.6*
Right: 3.0*
Cross caster 0.6*
As I drive it more, I notice more driveline vibes so I plan to make sure everything down below is lubed and then see what happens. If that doesn't do the trick, I'll start looking into a DC driveshaft for the front.
The truck does track much better and handles crosswinds much better. Much less fatiguing to drive, especially when you're trying to get home from West Virginia after a 24-hour race. I can also now drive it easily at 50+ mph on the twisty secondary roads near my home without angst.
I have to extend a huge thanks to Rick for all his help and patience with me through this project. This is the first vehicle I've owned that I've actually taken an interest in maintaining myself so I am learning a lot!
Also thanks to all the forum members that have responded with advice to my questions and ignorance--Christo, Beowulf, XXXR, SloMo . . . you know who you are!
:cheers:
