Hi,
We are pleased to bring you the fully plug-and-play Lutz Auto Speedometer Calibrator for the LC250 and GX550. This speedometer calibrator is fully adjustable and has no latency issues. After installing and calibrating it, you will forget that it exists! Ships quickly from the central coast of California. This Speedometer Calibrator is designed to adjust your LC250 and GX550 speedometer to display the correct speed, compensating for any modification that affects the speedometer calibration (ie. tire size). This will also update the rate of the odometer to match the corrected speed.
www.lutzauto.com
www.lutzauto.com
2024+ Lexus GX550 Speedometer Calibrator | Lutz Auto
Plug and play for the 2024+ Lexus GX550. The Lutz Auto Speedometer Calibrator corrects the speedometer and odometer after larger tires, gearing changes, or any other modification that affects the factory speedometer calibration. No cutting, splicing, or wire modifications are required, and the...
www.lutzauto.com
Toyota Landcruiser 250 (2024+) Speedometer Calibrator/Correction Device | Lutz Auto
The Lutz Auto Speedometer Calibrator is designed to calibrate your Toyota Landcruiser 250 speedometer to display the correct speed, compensating for any modification that affects the speedometer calibration (ie. tire size). This will also update the rate of the odometer to match the corrected...
www.lutzauto.com
