Land cruiser intervention
Pensacola, FL
Ok, So I bought another 80, actually a 97 lx450. I may need help.... I think I'm ready to admit I have a problem.
I do have a question. My latest came with 3" lift with a 1" spacer in the front and 35's. The previous owner didn't complete the camber correction so she wants to "walk" a little or pull when changing lanes. I am used to driving my 40 on 33's so this really doesn't bother me too bad. Question is, if I fix the camber issue, am I likely to get any vibration from the front driveshaft angle?
I think most are hesitant to jump into this can of worms with you. If you fully correct castor at that height, you may get a vibration as you suspect. People have different results which I think is greatly due to expectations and how much they are willing to put up with. Personally, I'd rather have a cruiser that drives in a more predictable manner with a vibration than smooth and wanders. Coming from a 40, the vibration might seem tolerable to you.
Honestly every truck behaves different. Look @Dissent recent threads. I'm running a similar setup, but don't have his issues to a degree. I am borderline thinking about going to a front DC.
So I guess my answer would be get plates to correct the caster and go from their on what on the neg side they could do and then correct that.
Can of worms for sure. I got away with min. fixes, but mine could be better at the same time.
I have the exact same setup, but with the caster correction plates. I finally removed the front spacers to correct that wander. I'm pretty happy with it now. I don't have any driveline vibration issues. Of course, I drove a 55 for ten years, so my point of reference is a bit skewed.
:lol:
Pretty much the answer I was expecting. From reading other posts, it doesn't seem like the DC driveshaft is as expensive as I was expecting. This truck is a weekend truck for wheeling/camping/fishing. I don't need it fixed right away, but I will probably end up ordering a new driveshaft and doing the camber correction at the same time. I had vibration in the rear of my 40 until I installed shims to correct it... drove me crazy. Thanks all
Before buying the DC shaft, ensure your pinion is pointing directly at the output flange of the transfer case. Mine was off 1.55* in back and I believe 1.85* in the front so both DC shafts vibrated. Fixed the rear by using the OEM shaft and adjustable LCAs. Still 'fixing' the front. If the DC shaft isn't in 0* alignment with the pinion (perpendicular to the pinion flange), you may still have vibrations. The trick is to ensure you have 3* or less operating angle between the two flanges in relation to the angle of the driveline.
