L/C Hub conversion kit
Here is what I have found. I took mine appart and if I ever have problems will put manual hubs on. They look to be easy to change. I think these are NAPA part numbers but could not be sure as they are out of context.
I did try and search NAPA online but it did not work.
want to get rid of your elec hubs?
works on HZ<PZ>LJ<KZ
order these part numbers:
43502-60080 front hub assembly
43530-60041 manual locking hubs
You only get what you pay for!
Toyota Aisin hubs are very strong, and they have COLLITS to keep them tightly fitted.
They never work loose.
Supper winch and AVM and a lot of other after-market hubs don't use collets, so can be prone to working loose. Then the dowells will break . :mad: I would pay the xtra for a better product.
oldblue:
got the message :)
I have checked the web and now see the difference! In Poland there is not much Toyotas around so getting the spares will not be easy thou... In my car one of the hubs got worn out beyond repair and I have to replace the inner parts almost completely. To make it properly I want to rebuild both hubs at the same time. Temporarily I am driving with both of them locked so there is no much moving parts inside: my inner hub was rubbing against inner hub wheel ring where there used (!) to be some brass surface.
Anyone has two Toyota Prado Aisin hubs to spare?
