Hi all,
I’m chasing a random metallic clicking noise from the front right of my 1995 KZJ78 Prado and hoping someone might have ideas.
Noise is a metallic click or ping from the front end. It only happens when the vehicle is moving and seems random rather than rhythmic. I can only hear it with the windows up and not from outside the car. Usually noticeable over small bumps or rough surfaces. Braking does not change the noise and I cannot reproduce it when the vehicle is stationary.
Work done so far:
Things I have checked:
Trying not to replace everything in chasing the noise.
Any suggestions appreciated!
Thanks
Work done so far:
- Replaced the front sway bar D bushes
- Lower shock bush looks OK and I could not move it with a pry bar
- Braking does not affect the noise
- Front control arm bushes flex slightly with a pry bar but it seems like rubber movement rather than sleeve movement
Thanks
