unless you hit some kind of quick sand there is really no excuse to ever get stuck in the sand. A shovel it the only tool you really need.
l be a shame if these vehicles stuck ... looooooooooooooool
For any sand the only tool you need is a front locker
@Volcano cruiser
I have found that A/T tires and better overall than sand/passenger tires. They last longer and aired down they perform just as well. The A/T tires are much better on road than sand tires and in the mud also. In the dunes, they are just as adequate aired down. Keep in mind I drive a heavy 100 series with close to a Ton added to the stock weight when fully loaded. For vehicles carrying no extra load what so ever like in the video, any tires would do.
One can even drive a light passenger car will little trouble on the sand. I had a friend follow me in his ford crown victoria for half and hour across the sand with no problem. You'd just need to keep the momentum, avoid sudden braking, sharp turns and you'll be alright.
I personally carry several forms of self recovery. I sometimes go alone to the desert so I don't want to risk it. A shovel is usually all you need. if there is another vehicle, a snatch strap would save you the trouble of digging with the shovel most of the time. For single vehicle recovery I personally use max trax, high-lift jack or exhaust jack depending on the situation. The winch is almost worthless in the desert as means of self recovery. There are no trees and using an anchor like the portable rescue tree is really troublesome. It failed to anchor on two occasions for me one in the sand dunes and another in the mud. It is very useful however to get another vehicle out. I've used it many times to get stuck vehicles out of sand and mud.
@Volcano cruiser
I personally have the portable rescue tree (PRT). I only really needed to use it twice and in both occasions it did not anchor to the ground. The first time was in really soft sand in the Dunes in Saudi Arabia. The pump I was carrying is really small and I did not want to air down to get myself unstuck. I got the PRT out and had the screw on it set for soft sand. Held it like I've seen in the manual and had my friend operate the winch. it kept digging in the ground and pulling me with it towards the vehicle until I was knee deep in the sand without it ever anchoring. I am a big guy and everything I tried to get it to anchor failed. So I gave up, aired down, got myself out and spent the next hour airing up with the small pump.
The second time I was in the mud and wasn't really planning on going through any mud in my early morning outing. Did not have the trax nor the exhaust jack either. Got the PRT out, dug a reasonably sized hole to get things started. It did the same thing and kept pulling towards the vehicle without anchoring. It actually disappeared completely underground yet failed to anchor. I had a recovery strap on the PRT so I pulled it out later. I was really stuck that my friend whom I called to get me out came and got stuck with me. The other friend we called couldn't get either one of us out and it took two tow trucks just to get me out.
Maybe the PRT is designed for lighter vehicles and couldn't handle the weight of my 100. Maybe I was too stuck for it to be useful. I haven't tried the pull pal as we don't have it locally and shipping would be extremely expensive. I did try with someone in his nissan patrol which is lighter than my 100 three different types of boat anchors for winch self recovery in the mud. Only one showed good potential but needed some modifications to make the blades slightly bigger. I don't know where he got with his idea as I lost contact with him.
Just to illustrate some of the things I mentioned here. Today, I backed up into what looked like the tracks of an earth mover in the desert. The rear of the cruiser was sitting on the axle and rear tank. The front wasn't as bad though. The cruiser was full with gear in the back. The middle row was full with gear photography gear as well. Got the shovel and did some digging, jacked up with the air jack, got the trax out and aired down to 20 psi. I know it's an overkill and that I could have got out with just one method, but I wanted to make sure I get out from the first try. Locked the front, central and rear lockers and got out smoothly from the first time
Between the two of us, we had like 7 cameras in the back seat. But when I told my friend to take a photo he decided to use his phone! So sorry for the bad picture
Hey! It's been a while since I've seen you around! How are things? I just have a question regarding your 100's weight! Have you passed the 3ton scale?
Hey my friend, we should get together some time. Let me know when you are free and maybe we can get Saleh to come too.
I haven't checked on a scale the weight of my 100, but I wouldn't be surprised if I've passed the 3 ton mark. Especially considering that the stock net weight of the UZJ100 is about 2.4 metric tons AFAIR.
