So, I never had a single issue with overheating and then my OEM radiator sprung a leak. I decided to just do everything in order to preserve the same (or even better) cooling. I purchased an Aisin water pump, Toyota thermostat, all new hoses and the highly recommended Koyorad 1918. I fully flushed the system, disconnecting the heater lines and everything to get all the coolant out of there. Then I ran some distilled water through a few times just to make sure all the old, dirty stuff was out of there.
When the new stuff arrived, I immediately noticed that the Koyorad was only a 2 core radiator, but because of all the positive experiences on here, I went ahead and installed it along with everything else.
Initially, everything seemed great. I thought the whole thing was a success. I went out wheeling about a month ago just outside of Vegas. The temperature was about 117 as I crawled up out of a wash for a number of miles. The gauge began to creep up. I found that if I kept the engine revved, I could keep the temp down so I figured, the blue clutch fan mod would fix me right up. I just finished that this past weekend and the fan seems to work exactly like it did before. I towed a trailer over the pass today (2000 ft climb over maybe 7 miles), it was just over 100 degrees. Once again, the truck started to heat up.
I am thinking that my problems may be due to the 2 core radiator rather than the OEM 3 core that I replaced. That being said, do you guys have other suggestions? Do you know of a good 3 core replacement for this.
By the way, it's a 1994 FZJ80.
Thanks
Thanks
