knuckle studs....thread/pitch? (FAQ)
woody
Adulting: do not recommend
Staff member
Admin
SW Utah
just my luck....decided to torque down the steering arms and discovered one is stripped....pulled the threads right outta the knuckle casting....
and, dumber, I did a hack JB Weld repair to see if it works (betting it doesn't)...and didn't take the time to check the thread/pitch of the studs so I can order up a helicoil set....
anyone? minitruck/60-series knuckles, the 4 studs into the knuckle itself, "believe" the threads for the cone/nut are different too....
I'll have mine torn apart tomorrow. I thought the later knuckles were 12mm and the earlier ones were 10mm. Actually, i hope to have both kinds torn apart tomorrow and the 4x4 labs arms going in.
Nothing like scrambling at the last minute.
Please tell me all the knuckle stud problems you've been having is because of the rock ram and not the 4x4 labs arms.
I've had the hydro-assist a few months with no problem, but our last trip out a guy "clearenced" the threads on his large knuckles and he had a 4x4 Labs (or similar) setup. This is the third mention of hydro-assist causing knuckle problems ........ maybe I need to order the Marlin 6 bolt knuckles sooner rather then later.
Of course it could just be Woody's driving habits too! :D
11mm stud, pre 1979, I would not tighten them more than 65 foot pounds....
12mm stud, 1979 and on, FSM states 65-79 foot pounds.....just installed the ARP knuckle stud upgrade along with the removal of a Warn birf eliminator kit and install of 30 spline Longbling...
Do not have the books in front of me currently, but these numbers will not cause you any issues.....
Good luck!
-Steve
Drum brake and early disc axle knuckle studs, 11mm diameter, FSM states 40-60 foot pounds of tourque, and 4.0-5.5 pounds of preload on the knuckle bearings, while the knuckle is rotating..
1979 and later disc axle knuckle studs are 12mm diameter, FSM states 62-79 foot pounds of tourque, and 4.0-8.4 pounds of preload on the knuckle bearings, while the knuckle is rotating...
:beer:
