Knuckle stud upgrade
Folsom, CA
Anyone do the Dana 44 stud upgrade to the mini truck knuckles on a FJ40? I read the write up on it and it seems pretty straight forward. The question I have is the new holes for the Dana 44 studs drilled through the old holes for the stock knuckles, just with the propeer larger drill bit?
i opted for the Front Range stud upgrade....no drilling/tapping, and significantly higher grade hardware. Allow for more universal stuff, in the rare chance it DOES break....
Range kit
THAT'S THE WAY TO GO! No drilling, or jig building for the knuckle. A little steep in price but not if you factor in the time saving. I am going to do it before Rubithon
Cruzila went with the Dana 44 studs and is very happy. I just bought mine and am doing the same. I have the 4x4labs hi steer kit and luke said not a problem, in fact he said he was thinking of offering a set with this option. You can get the entire kit, studs, nuts and cone washer for partsmike. Tell him what you are using it on instead of buying the kit and then one extra of each. With tax and all I think I paid $58. Good luck
Like Woody, I have been running FROR's hub & knuckle studs with great success - simple / easy upgrade
Joe
