knuckle stud replacement
Always a good idea to tell us what year??
DougM
Those are the same replacement studs I got from CDan - they are a Toyota replacement for the original studs.
The cone washer 'slits' are not new - that is how they compress.
Good idea to make the change though - much easier to check torque with the torx head studs.
As for getting out the old ones, if they are like the OEM studs on my '96 cruiser, you can grab them with vise grips or Sears/Craftsman (and probably others) makes a 'stud remover' that is used with a socket wrench.
If you purchased anything but the torx head style, probably not worth your time to change them. Order the torx head style and do it right.
Either way, good luck!
You can double nut them to pull them out. I just did them this way on my mini-truck knuckles and it worked great. Run the first nut down until it is almost bottomed out, then run a second nut down on top of it and tighten them against each other very tightly. Then, with the wrench on the lower nut, turn the stud out. The friction between the two nuts will prevent the lower nut from spinning off the stud and will instead spin the stud out.
Ary
Ary
I considered the double nut method, but since my old ones cracked, I'm not sure if they'll be strong enough.
I just took vise grips to mine and they came out without too much work. I held the knuckle housing in a vise. Don't know if you are doing it on the truck or have the knuckle housing off the truck.
Good luck.
