Knuckle shims- old or new?
Houston, TX
After much research and reading tech articles, I am in the process of rebuilding my first disc brake axel to go under my 1970. I 've learned a lot but still have a question. I am installing new knuckle bearings. Should I go back with the old shims in their original locations or should I try to match up the old shims with new shims from my rebuild kit? I do not have the SST and was counting on the old setup to get me close enough. I do think I can come up with a scale. I bought a front axel maintenance manual from SOR but was dissapointed with the info it contained. Nothing on knuckle shimmimg. All advise appreciated.
I think the SST is more important when swapping knuckles. I would either put the shims back the way they were using the old ones, or if you clean them well, they usually have a thickness stamped on them. IIRC there are basically three...thin, medium and thick. Mine had a medium and thin on top and a medium on the bottom.
HTH
Ed
I think it also depends on the tire size too. IIRC, I did mine at about 6-7 pounds with 33's, 9ish for the 37's with all the bolts top and bottom at spec. you want to make sure that you're making the decision to add or subtract shims due to the tonage on the fish scale and the amount of lbs you select to go with for tire size. I wrote down what I had in there when I took them apart, but it eneded up being totally different when I put them back together with new bearings. more shims, less resistance when you turn, less shim = more preload. it might take a while to get right, but this is how i did it.
hth, mike
Just went through this. I put the old shims back in and got 5 lbs preload. I had a thick and medium on top and a medium on bottom, both sides the same. I reduced the top and bottom by one "step" - replace the mediums with thins - and got 12-13 lbs, which is where I left it. Could have split the difference but would not then have factory positioning, and I've read here that 12 lbs is fine for larger tires. Better wear out my 33's and get some 37's on there I guess.
