Knuckle Seals & Valve Adjustment
New York & California
Website
www.rbfilms.com
Hi,
I have a 1997 Lexus LX-450 without Lockers.
I had three (3) different dealers look over an FJ-80. One (1) before I purchased the vehicle and two (2) after the fact.
One (1) Toyota Dealer said I need to replace the Knuckle seals and two (2) of the others (A Lexus Dealer and a Toyota Dealer) never said a word about it.
I questioned one (1) of the two (2) Dealers who said nothing (Lexus Dealer) ... and they say it is typical for these vehicles to "Sweat Grease" from the Knuckle seal. It is normal and I should not worry they said.
However, that same dealer that said nothing told me I needed a Valve Adjustment. None of the other two (2) dealers said I needed such a thing. When questioned, one (1) Toyota Dealer ... the one who said to replace the Knuckle Seals, said that the engine sounds were normal for this vehicle.
Any thoughts or comments on this? Is it true that some valve / mechanical noise is common? Do the Knuckle Seals normally "Sweat Grease" as they said?
Rich
The rule of thumb:
Once you got your 80 you can no longer listen to any mechanics because they know very little about these vehicles. This rule applies all over the world, believe me. You will be better off reading the forum, downloading FSMs and doing it yourself or finding a mechanic who is willing to listen and follow advice on how to work on the truck.
And now the answers:
1. The knuckles tend to weep some grease outside. If it is just a thin layer of a few millimeters, then it's good. If you have a 'blob' of grease the size of a golf ball then it's not good. You have two options:
- the better option is to take things apart and re-grease the knuckles. You will find a post on it HERE. Obviously you will replace the seals while you take them apart as it would be stupid to repack your birfs and keep the old seals.
- the worse option is to take your wheel off (or not if you have small head and hands) and locate a square nut on the upper-front part of the birfield. This square nut has a standard size that tools have. You put a socket wrench extension and a 13mm wrench on the other end to unscrew it. Then you put a grease gun and pump quite a lot of grease inside. This does not solve your weak seal problem and also you won't know if your knuckles are greased or not, but it's better than doing nothing. At least you compensate for the grease loss by this lubrication. But it's also bad for the environment to leave grease all around, so you should really take your time and do the birf job.
2. The engine in your Lex is really quiet in spite of its size. After it's warmed up and you open the hood, you should hear just a moderate humming and no rattles or squeals. If you hear squeals, then spray the belts with some oil. If the squeals are gone it means the belts need replacement. If you hear some sort of clapping or chattering (you know, like those flamenco people who clap their hands quickly) it means the valves need adjustment. This is not a big problem and doesn't render your rig un-driveable but it creates a faster wear of the components so it should be done fairly soon.
Thank you...! :)
Unfortunately, I am not a skilled mechanic. Given the time and tools...with a good lift...I might be able to do some basics....but I just don't have the time. I run my own business and it is all consuming of my time and energy.
I had two (2) seals replaced ($815) as they said they were leaking badly. I will check the chattering....I am not a mechanic so I will have to get this work done ($450).
I wish I was more handy as I could save a ton of money. I just put about $2,700 in to the truck and did everything it could possibly need from every flush and fluid change possible to a wheel alignment, knuckle seals, thermostat, caps, rotors, wires, plugs, filters, and so forth and so on. Add the $450 or so for the Valve Adjustment, another $200 for Landtank's seat rail extensions, yet another $500 in serious detailing, plus the $1,250 I put in to a Viper Alarm and Automate GPS and I have over $5,000 in to this vehicle in just the first month I have owned it. Yikes....!
I did not anticipate the vehicle needing this much work. I purchased this vehicle because it was the cleanest I could find and seemed to be in tip-top condition....which in all honesty, it is. The vehicle just needed more maintenance work than I realized.
I know I got a great truck because both the mechanic and the service manager asked me if I wanted to sell them the vehicle. That would make the third person in a month that asked me that question. It looks and runs great so I am very happy with my purchase.
Now all I need to is add a Denso 170amp Altenator, Optima Deep Cycle Yellow Top Battery, a Ham Radio, Linear Amplifier and Antenna, Cell Phone Amp and antenna, an ARB Bar and some lighting and I should be set for a little while anyway.
Personalizing these FJ-80' is fun...but for someone not mechanically inclined like me, very expensive.
Rich
The rule of thumb:
