Knuckle Rebuild
Go the DIY route! You'll get intimate with your rig and it's a real eye opener on the condition of it. Mine isnt going to hit the road anytime soon so I am taking my time and taking notes on possible parts to upgrade. The only complaint I have is the mess involved. Lots of paper towels covered in goo! I have found that if you want to avoid using de-greasing chemicals, you can use some laundry detergent and Simple green. I soaked my knuckles in hot water, Tide and SG, then used my fingers and wiped out the grease. The globs of goo floated to the top and were easily disposed of by skimming them off the top of the water into a waiting garbage bag.
do it your self and save your money, its not hard, just takes allittle time, lot of grease. get a FSM, call curt at cruiser outfitters and he'll fix you up with what you need. plenty of post here covering it also.
A good link with nice pix if you want to pull your Birfs apart to clean and swap sides.
Rockhound
disassemble Birfield rebuild
Rockhound
Why would you swap the birfields around? What advantage does that offer? Does one take more abuse than the other due to the offset of the differential...?
Birfield tools
Special tools I bought for my knuckle job: 55 mm socket local auto parts, brass pipe with threaded plug (poor man's drift), 1 1/2" slip/thread copper union, galvanized union, nipple & floor flange to make a birfield remover (as suggested on a thread of which I can't now find). The birfield remover slides over the axle, copper on the joint and the flange gives you a place to hammer - this is only way I could get mine apart.
Besides being completely doable by almost anyone and also saving a bunch of money, if (when) something goes wrong with the front end on the trail, that is not the time for your first dive into the front axle. You will be so happy to have this knowledge at some point down the (dirt) road.
do it yourself.......
if you meet the following criteria:
1) you have the time to do the job properly
2) you have a safe place to do it
3) you have the required tools do to the job properly
4) you're mechanically inclined
5) (this one's optional ) if you can have somebody who's done it before show you how to do it and/or have the FSM on hand
doing a knuckle rebuild is definetly not rocket science. it's a messy job and it takes a little while. the more care you take in doing the job right, the longer it'll last.
check out the links in the answers above and make your decision from there.
like dan mentioned, contact your local TLCA chapter, i bet they'll be more than willing to help.
georg @ valley hybrids
Do it yourself. Get the FSM you'll enjoy it for lots of things not to mention the ones previousley posted. Don't buy a 55mm socket its not correct. Don't buy a 54mm impact socket w/o checking to see if it will fit inside the hub. NAPA carries a KDS 2 3/32 "spindle wrench". It is the perfect fit...I had to file the powder coat off to get it one the spindle nuts... posted about it when I did my knuckles.
Have fun and enjoy... It does take a lot more time when you clean up and paint!
I would recommend using a socket as you will have to use it when reassembling. Hard to use a torque wrench to set the nut properly if you don't have a socket...
The snap ring that goes on the outer edge of the axle, just befor you place the locking hub on. How in THE HELL can I get that on. What size bolt do I need to place into the axle to make sure it doesnt slide back in?
I am also having problems getting it "open" it doesnt want to stay on the snap ring pliers thus wont go onto the axle. any tips or tricks?
You need a pair of angle tip lock ring pliers (SK7636)
angle tip... ok. can those be purchased at any specific tool store or do I need to order them?
I bought them online. If you google for SK7636 you'll see what you're looking for.
many of the mud vendors sell them as well, including marlin, myself,.......
PS: i usually put the closed snap ring pliers into the threaded hole in the end of the birf, then push them apart and pull the birf out. it's the easiest wand fastest way to make sure the snap ring will seat all the way in the groove on the birf.
going to pick the lock ring pliers up at granger, they have a local shop. what size bolt goes into the threaded opening on the birf??
sheesh... don't give away all your secrets :flipoff2:
but if the snap rings are in the birf, how do you use them on the snap ring itself??
There are external snap ring pliers for that. They have a waffled surface to keep the ends of that ring from slipping. An absolute must-have. Even checker has them.
How hard is it to do this and is their any special tool I might need? Have done some work on my rig myself but nothing major or should I just pay and have it done? anyone know the cost to have this done? anyone out there that can give me a refferal. I'm in Austin Tx. Thanks, Rich
It's not that hard if you're familiar with working on cars, but it's definitely helpful to have someone around that's done it before.
Having a shop do it will cost close to 1k.
If you were in KY I'd offer to drive out to your house and do it for :beer:
I am on the tail end of a knuckle rebuild and a brake swap, new rotors calipers, lines. I had VERY little experience. I had changed oil a few times and changed a fuel pump out of a 77 chevy monza back in 93. This job, with the help of the FSM and glorious members of mud, is 100% doable. Make sure you have ALL of your tools, and most importantly the FSM. I put things in ziplock bags, and labeled them with sharpies as I took it apart. Its a great way to get over the nervousness one might feel for working on a vehicle. It may seem daunting, but it really truly is no different than say changing a tire, just a bit dirtier.
