Knuckle Rebuild - SST
PNW
Completing the same job as well. My 93 lc had a wheel bearing and the lower trunion bearing fail due to a service shops inability to do things correctly (That’s another post though). What I have a question about is the SST knuckle-centering gauge. This is needed to gain the correct shim sizes for the trunion bearing preload, etc. and to measure axle thrust etc. Replacing all bearings, seals, etc. with the total knuckle rebuild kit from Spector. Now due to the fact that this is a total rebuild, I need the SST for this..? The SST part # that I ordered from OTC was 0963460014. While looking throught the how-to-guide for the tool I noticed the SST # 0963460012. Now one thing I had a problem with was locating this SST# in the FSM and how to use it. I spoke with an OTC Tech and he told me that part # 0963460013 (that everyone on this site and others quote) did not exist but that the only SST knuckle centering gauge part # for the 93 lc was the 0014#. I said okay and assumed this was the superceding SST. I looked up the How-To-Guide for the tool on this site and it seemed pretty simple. I also reviewed the FSM for the procedures of the knuckle rebuild for any minor details that I may had forgotten. When I received the SST I went to put it right to use and found that the instructions and the tool I received did not seem to match up correctly. It seems that the instructions say to remove the oil seal from the inner axle and install the SST with the collar (g) on to measure inner thrust and place your mark for the shim measurement. Well, I had removed the inner oil seal and placed the SST within the axle shaft housing, as per how-to and the SST was too small. So, I again looked in the FSM to find a reference or something that would give me a clue...and nothing. Maybe I am not looking in the right spot in the FSM...SA…? I decided to pick up the new inner oil seal from the kit and place it around the SST (c) in the how-to guide and it fit perfectly. The issue with this is that the picture at the top of the guide shows the inner axle oil seal out with (g, c, and d) installed in the inner axle tube. The outer dia. of collar (c) is smaller than the inner dia. of axle tube where the oil seal is to be. Now, the instructions and picture seem to say or show something different and or contradict themselves. If you use the inner oil seal instead of the collar (c) and try to complete the measurement, the lip of collar (c) does not end up in the place where the picture shows in the guide, it will sit inside the lip in the axle housing. Am I not reading something right or what? Do I have the wrong tool? The FSM does not seem to mention the need for this SST. I know the older cruisers need the thrust measured with spacers etc. so does the 93 not need this, yet how do I measure for shim thickness of the upper and lower trunion if this cannot be completed?
Another issue with the tool is that I cannot complete the a, b, measurements because the tool shaft is not long enough to allow the placement of the top bolt.
http://www.ih8mud.com/tech/knuckle-center-fsm/knuckle-centering-tool.pdf
Need some help here and sorry for the lengthy first post but from what I have been able to conclude from this sight is that you all collectively have great knowledge and thought I would start here. Thanks for the welcome and I hope to get this answered ASAP so I can back to work.
FYI...The original top bearing cap shim size was .20mm and there was no lower shim on the control arm.
Thanks again in advance for your help.
Others can chime in on this, but from what I remember, the 80 knuckles are usually almost always on the money when it comes to trunion bearing preloads.
I used the factory shims and the preloads were perfect.
I did not use any SSTs, and I dont think a lot of others did either. Ive only done one knucke job, so others input should be better.
I could be wrong, but I thought the SST centering tool was not required in the FSM for my '97. Will check when I get home.
x2 hntashdjian
Edit: Yep, The only SST is the press for removing the steering arm and the top bearing cap. No centering tool.
That is what I was noticing though I did find in Section SA that there is an SST for removing the upper and lower trunions. There also seems to be another section that shows the use of the same tool for installing and seating the trunions. Also found a reference to adjusting the the trunion preload by determing the shim spacing but no other reference to, as far as a section or page like others do. I am a bit confused though because the manual mentions the lower shim but there is no other reference and the parts fiche shows only shims on the top trunion and not the lower. Do we not need a shim on the bottom and just the top. Yet, how are you supposed to do your measuring when starting from scratch to know which size shim and where. I did notice before removing the spindle that the brfld seemed to be touching the spindle on the top edge. This does not seem normal and I would imagine that this is caused by not having the correct spacing or shim on the bottom trunion. I know this seems like a lot of info and many problems but I think if one could be solved we could solve the rest fairly easily. Again when I removed the lower control arms there were no shims. Is this typical?
Thanks again for your reply.
Yeah, that's the one in my edit, above. It's not required, but it's very helpful.
You don't, per se, measure any distance when setting pre-load on the knuckle. Instead, you measure how much force it takes to swivel the knuckle. This force depends in part on the thickness of the shims. So you use different shim thicknesses [you shouldn't have go too far from the one you took out ;-) ] and test to see if the rotating force is correct. When it is, you have the correct pre-load.
I'm not aware of the need for lower shims (steering arm) on FZJ80s, so I think your shim condition is typical.
The alignment between spindle and birfield you describe does not sound typical.
"The alignment between spindle and birfield you describe does not sound typical."
Ya, that is what I thought but what could cause this. I mentioned something about the lower trunion needing a shim...could this fix the problem?
What about the SST that I purchased? What year of lc is this used with then? It seems strange to not have to use the tool when there obviously is much to be determined with it.
I appreciate all of your comments and help so far but still feel stumped...
Thanks
"Inspect the brass bushing inside the spindle for wear."
Not sure if this is what I was supposed to notice but I feel this would be the major cause of the axle/spindle alignment issue? Purchased these for both sides and replaced already. When I reinstall the spindles I hope this is the key since the bushing is what the axle rides on in the spindle.
Thanks
Well, you should check the brass bushing. But I was referring (and my link points directly to) to cruiserdan's post #8, which says:
cruiserdan said:
Re:Front axle service requirements
A minor tweak to Joe's list, if I may.
Joe, it appears that you have yet to do your 80. Luckily for us the knuckle is shimmed only under the top cap so it is not necessary to center it like you would on a 40/55/60/62.
Just a hair to split........
Dan.​
Oh...Sorry about that miss. I did go back and read it again and noticed that but, did not have a chance to reply. Yes the bushings were checked and repalced. Well, I am glad to know that the SST I purchased is useless so I will have to make a return.
Thanks again for everones help and sorry I missed that in the post. I thought I read all on the knuckle rebuilding process but I'm glad to see everyone is eager to help.
Great forum and glad to be a part of it.
