I am in the middle of a knuckle rebuild on my 96. Came apart easy and everything looked good except the grease was soup and leaking. Cleanup took forever. Got my parts yesterday from Kurt and started putting everthing back together. Put in the axle seal and top trunion race. Then I proceeded to drive the bottom race in BACKWARDS. Idiot. When it is upside down there is no ridge at the top to drive it out. After much cussing I was able to get out by hitting hard with a brass drift on the taper until it moved enough to get on the ridge at the top. Took a long time. Lesson is be very careful with the correct orientation of the race before you drive it home although I may be the first to ever screw this up.
(a little inside humor for those of us who sit on the other side of the bleachers)
