Knuckle rebuild cost?
Vidor, TX
I'm about to get back into an 80 and I'm pretty excited. The one I'm looking at has 140k miles on it and I don't think it's had the head gasket changed or the knuckles rebuilt. I'm trying to figure out how much I'm going to have to sink into it after I buy it. What is the cost of the front axle rebuild? I have basic mechanic tools, but the specialty tools for the job will have to be bought to do it. If I do it myself, how much is it going to cost me to rebuild the front including parts and specialty tools? I've been out of the loop for a while, isn't there someone on here that sells rebuild kits and such?
IIRC the only special tool you need is the 54mm hub socket. Other than that its just hammer, punch, and a socket to push in the new oil seals.
Here is the link to the FAQ front end service.
https://forum.ih8mud.com/80-series-tech/78276-front-axle-rebuild-faq.html
As well as the list of tools that are used according to Romer
First Suggested Tools and supplies:
Items to start with:
1/2" Ratchet
1/2" 18" breaker bar (or pipe to extend ratchet, might not need this)
1/2" 3" extension
1/2" 17mm socket
1/2" 14mm socket (3/8" would work too, for spindle bolts, which were really tight)
3/8" Ratchet
3/8" 6-8" extension (used only for a beating tool, don't use a good one)
3/8" 3" extension
3/8" 12mm socket
1/4" Ratchet
1/4" 10mm socket
Snapring pliers
54mm hubnut socket (probably 3/4" drive, so 1/2"->3/4" drive adapter maybe)
Small pipe-wrench (10" one, look below for picture of use)
Heavy hammer, something solid, 2+lb maul or something.
Good slot screwdriver.
Brass Drift
Call Cdan at american toyota at 800-432-6668 and mention this site, he will get you every thing you need.
Price depends on how much of a rebuild you want to do?
Are you just changing seals?
All bearings?
Both?
CruiserDan is the man you want to talk to when you order your OEM parts.
You might see if there is a cruiser club or dude nearby who has the tools. You might be able to borrow them..maybe make a friend or two.
I spent ~$1,000 on my rebuild but a substantial amount of that was tools and items I could reuse (grease gun/brass drifts/pull scale etc.). I also changed out my front rotors and installed all new bearings (trunnion + wheel).
My understanding is that you can get a bargain "kit" for the axle rebuild for around $200 to $250.
Even at $1,000, I saved money compared to having my mechanic do it (even though I had to go back in and fix a broken c-clip after the rebuild).
Riley
I wouldn't do this job without a torque wrench. CDan for factory parts or Kurt at Cruiser Outfitters for an aftermarket kit, IIRC ~$115 w/bearings.
Thanks for the info guys, I wanted to make sure I wasn't in for a $2k job. I'm going to buy the 80 on Wednesday as long as it passes my inspection.
