Of course the NAPA ding dongs gave me the wrong discs for up front! I brought them the exact part number and everything. Lovely. When I tried to install the studs and they just dropped in, totally loose, I knew something was up. Maybe they'll take them back? I'll go up there with a hub and show them....
Well I greased everything up, and installed the Marlin's inner seals, and the inner axle/birfs, then more grease. Installed the felt, rubber & brass wipers, and installed new bearing races and greased up the new bearings to stick them in place. I proceeded to the knuckles, which I couldn't install over the housings/bearings w/o removing the bottom knuckle plates. I did that and reinstalled without cranking everything down.
How do you make sure the bottom bearing seats properly? Maybe using an air tool is a bad idea here b/c the knuckle plate gets uneven rather quickly and won't seat in the knuckle housing properly (& a tight fit to start with too). Of course I used an air tool.....
Next was the steering arms, but I couldn't find the damn cone washers and it was getting late. More tomorrow.
This task turns out to be time consuming and frustrating even with good planning. Messy too, but everybody should do it at least once.
Next time it'll be by feel in the dark and mud for sure.
