Currently in the middle of doing a knuckle rebuild on my cruiser and found excessive metal shavings on brake dust shield and inside abs sensor when tearing down. Found my spindles scored so currently have some on order. I found excessive play in both wheels prior to removal from wheel bearing.However after removing my knuckle for axle seal replacement I found some strange scoring near the top race inside the housing. Also appears the top race has some marks if you look closely. Has anybody ever seen something like this before ? Not sure what to do now if I should sand and try to smooth out and install all new parts or do I need to replace the whole front axle? Haven’t even got to the passenger side yet. Any suggestions would be greatly appreciated.
1995 with 230k miles with no prior maintenance history , judging by axle seal more than likely all original
