knocking, rattling, over drivers visor
Loomis, CA
Drove a friends '93 yesterday to listen for a noise when hitting bumps at pretty much any speed. It really sounds like it is under the headliner by the visor. I pulled off the visor and it didn't change. I opened and tilted the sunroof and it didn't change. I haven't found anything loose. He said it started after he hit a rock on the highway. I am going to my storage tonight to look at a Cruiser without the headliner to see what's back there, but if anyone else has had this I would appreciate any help. It is all stock, 171k, and it is kind of a rattle, plastic to metalish.
Pretty sure it's the sunroof, but you said it did it with it open? Mine does it too, but not when open. I plan on adjusting it and see what happens.
I slid it back with no change, tilted it up and I thought it went away, but it came back. I was thinking mabye a sunroof drain hose. I am not at home to check the FSM.
You could always pour some water down the sunroof drain and see if it drains into the headliner. Not a great test if it fails, but at least you'd know if it was the hose.
Don't the wires for the map light run up the DS? Maybe they came loose? Pretty tough to tell without pulling the headliner, which is a real PITA.
Sorry. No help.
My 94 does the same thing. Pretty sure it's not the sunroof. It's right behind the driver's side visor. I don't want to pull the headliner down, but I can feel it through the liner. feels like a thin metal rod. It's pretty annoying, I thought about squirting a little spray foam behind the headliner to quiet it down, but not sure what's behind there.
I fixed a noise on mine from the same area a few years ago. If I remember correctly there was a couple of wires (or at least something plastic) that run above the headliner on that side (kinda where the grab handle would be if there was one on that side). If you are careful, you can peel the headliner back enough to get in there with some silicone or something.
I think I pulled the weather stripping/molding back from that part of the door frame, then slowly peeled the liner off its adhesive right there. The adhesive was sticky enough to hold it when I put it back.
Aaron
Dug up from the dead files.......
OK just had a cold spell in our area below, -15 for a couple of nights and now we have a new rattle.
It sounds like it is right above the passenger visor, if you unhook the visor and force it down (grab the loose end and pull down lightly) the rattle stops.
Today I pulled the headliner back to get a look and I think it’s a glue failure between the roof and the roof support assembly right behind the front window. The visor attaches to this assembly and pulling it down keeps the two metals from rattling as the body flexes as you go over bumps.
Anyone else have this problem? I think the cold weather and a big bump broke it loose. I wonder if this is the same type of glue that was used to attach the hood support to the skin that seems to fail.
Rattles suck........
