Knocking noise while turning........
Camden, SC
My 92 LC is making a knocking racket only when turning sharp left or right. When center diff is DISENGAGED it's not as bad as when center diff is ENGAGED. What gives?
Can you describe this "knocking racket"?
Clicking? Popping? hard knock, light knock, hollow, sharp, etc?
Tie rod pop? Check tie rod joints on both ends to make sure they are also aligned together downward. My 92 had a similar problem and with a slight adjustment of the tie rods so the studs were aligned downward, applied grease and popping stopped.
I have a question....
When I make left turns, I can feel something on the steering wheel....like it's hitting or pulling something and it makes a noise. Any ideas? Thanks
Bushes gone?
Mine is doing that but getting the SuperPro treatment soon..... :D
How would I check to see if the bushes are gone?
Have a look underneath..
These poly rubberish looking things are bushes..
you can see straight away if they are good or not...
They vary in colour most common are orange and blue...
There are quite a few I must say...
Mine are totally shot and I get the same noise as you....
Will replace them soon...
Sounds like the birfs to me. Mine has the exact same problem, it turns silently and smoothly w/o the center diff locked, but when it's locked, it binds up and pops while turning. I will be watching this thread to see if anyone has any other new ideas though, I really don't want to replace a birf in my vehicle, but I think it's inevitable.
X2 on the birfs. My 94 had a front end knock when turning hard left or right. I do not have CDL, and I heard it all the time, slowly getting worse. I just picked up my rig today from getting the front axle rebuilt, including new birfs and drive plates (from CDAN, thanks!). It turns smooth and quiet now.
I replaced the front left rotor, 100 pads, and took me baby for test drive. Guess what? No more squeeling noise while making left turns and, I don't feel any pulling or skipping on the steering wheel at all. I love this truck! And it stops. Thanks to all of you here.
