Knocking 3FE? Help...
Utah
First off... It's not knocking anymore.
So here's what happened... I'll use a map of my neigborhood to show exactly what I did:
1. I got in my truck this morning, started it up, and let it idle for just a few minutes before I put it in gear. Didn't touch the gas, at least not to my recollection...
2. I put it in gear, touched the gas to go forward (duh), let off the gas, and turned around (I live in a culdesac, I was pointed toward the end). Accelerated up to the two way stop. Not too hard, though I normally accelerate more than one should :o
3. I turned left at the two way stop and started accelerating again.
4. I let off the gas to coast to the stop sign, but the throttle was stuck! I think it was from some mud left in the engine bay from my "locker testing" a few weeks back....at any rate, it scared me because there were small children running around. I took it out of gear and tapped the gas pedal, which luckily un-stuck the throttle.
5. Coasted to the stop sign safely.
6. I hit the throttle to go, then the engine started knocking like it was out of oil :eek:
7. Let off the gas, the knocking quieted down a bit. Didn't stop. "Maybe something got caught in the fan," I thought. I pulled over and popped the hood....definitely the engine. :censor:
So I shut off the engine and checked the oil....less than a quart low. Great, I still have over 7 quarts. Started it back up, and there was a slight ticking, sounded like it was coming from the bottom end. After a few light revs....it went away. Ran fine the whole day. Still runs fine. No knocking.
:confused:
Help?
More info:
I routinely change the oil and filter every 3,000-3,500 miles, using Valvoline 20W-50 (or Napa, which is re-branded Valvoline), and the big Napa Gold filter (re-branded Wix).
It uses about 2 qts per oil change. Leaks a bit on the driveway, and I have a sneaking suspicion that the rear main is going...
