I have been getting intermittent ec55 when pushing my 'ol dog (fj80 '93 with 300k+) pretty hard and it then retards timing and I get a loss of power. This is the rear knock sensor which I replaced years ago and spliced the wire. There has been no issues until the last couple of months. I took the sensor out and ensured that there was not continuity from the wire tab to the body of the sensor. (Hayne's recommended check for sensor integrity.)
I thought I would check the circuit from the sensor plug to the ECU (pin 14 on the 16 pin connector). I removed the ECU and pulled its plugs. I don't get continuity. As a sanity check I then decided to check the front knock sensor's circuit to the ECU (pin 6 on the 16 pin connector) - no continuity. Should I be able to check the integrity of the circuit like this? I thought I was being clever, but now it seems not so much. Thoughts? Thanks!
BTW, I am using a diagram that says it is for 1995-1996 1fz-fe ECU. My ECU says 1fz-fe on it. Additionally, the Haynes manual electric diagram indicates a 6 on the ECU for knock1 and a 14 for knock2. This is an encouraging cross check. Hopefully compatible.
Ron
Ron
