Kickdown cable revelation...could it be?
Hey guys. I had posted earlier about hard shifting. Thanks for all of your responses. I had investigated the kickdown cable earlier, but based on the DIY I figured it wasnt for my car because my setup was different. The kickdown cable was nice and tight when I checked it.
Here is why I thought the DIY wasnt for my car....
It said the kickdown cable is the one by itself lower in the assembly. It had 14mm nuts. When I checked my car, the 14mms were up top next to the accel cable. The cruise cable was in the lower position.
So I just had a revelation.....my cruise and kickdown cables are in the wrong spots!?
Can anyone confirm for me that I am right?
Its a 1997 LX450.
If I am right then the PO was driving around basically without the kickdown cable.
I have to go eat Turkey now otherwise I would be out there right now!
I cant imagine what a big difference it will make on the truck if I am right!
cheers,
george.
As you can see in George's photo, the accelerator cable (from the gas pedal) is connected to the top pivot location closest to the throttle body. The cruise control cable is connected to the top pivot location furthest from the throttle body. The throttle cable (aka kickdown cable, from the transmission) is connected to the (only) bottom pivot.
The idea is that as you press the gas and pull on the accelerator cable, the throttle cable is pulled out from the transmission.
HTH!
