Kickdown Cable Adjustment
30°54'01.53N / 84°04'56.04W
Before I get flamed for asking...I have searched the 80's section with key words like kickdown, kick down, kickdown cable, kickdown cable adjustment, etc.
Nothing coming back specific to the cable adjustment. Does anyone have a link to the instructions in adjusting the kickdown cable?
Thanks!
:doh:
Thanks rookie!
This is a post on "throttle" adjustment for the 1FZFE. Two questions...
1. is this the same as the "kickdown cable" adjustment and if so,
2. are the instructions the same for the '91-'92 3Fe?
On the 3FE the space between the metal crimp and the red stopper should be .5-1mm according to the FSM. When I adjusted mine and finally found the sweet spot it was more like 2mm so I would recomend setting it to 1mm and then using trial and error until it feels "right".
  • Like
Reactions: KTP
