Keyless Entry: beep, beep, beep... Which door is it?
NE Atlanta, GA
2011 200 Series. When using keyless entry, pushing the remote button or pulling a handle, I get 8 to 10 beeps and only the drivers door will unlock. I assume one of the lock actuators is acting up, but can't figure out which one. All the doors will lock when hitting the remote button and door lock button inside the cab. The tailgate still unlocks as well, but no other doors (except driver) unlock without manual intervention.
I've reset and changed settings for locks in the console and no change.
Any ideas on how to figure out which door is the issue?
TIA
Bump.
Anyone? Bueller?
Open and close all 5 doors, making sure that they did all unlock.
Lock the truck and listen for the lock beep.
If it does not beep, then one of the actuators is going bad.
The only doors that unlock by pulling the handle are the driver door and tailgate. All other doors give 8-10 beeps and don't unlock.
The tough part is trying to figure out which door is having the problem...
Have you tried replacing the batteries in the remote(s)? Could be a signal that they are weak, allowing only the driver and tailgate doors access perhaps. Better than the other guy a few weeks back who's LC would just shut off after 5 mins due to the batteries, once again.
