Key stuck in ignition
Is this a newly made key? If so, it may need to be wire brushed a little to round over the teeth. Otherwise, I would try some type of lock-friendly lubricant such as graphite.
I would also check whatever sensor senses that the truck is in Park. Not sure what mechanism the 80 has, but I had an Acura that had this type of problem and it was the Park sensor. I would put it in park, but the light around the P wouldn't light up. I would jiggle the shifter around until the P would light up and then it would let me take the key out. Just an idea.
sometimes I have to bump the shifter forward with the palm of my hand when its in park. This does whatever it does to allow me to get the key out. It doesnt happen very often so I haven't bothered looking into any adjustment.
The transmission shifter is easily accessible on the passenger side of the transmission. Very easy to adjust, I needed to adjust mine after my body lift as it did the same thing that you described.
Been a known issue with the little bump of the shifter to release the key. Never has happened much for me. Saturday the little bump just didn't work and the key just wouldn't come out stuck at ACC. After lots of :bang: :censor::censor::censor: and jiggling the key, it finally turned off and I was able to remove the key. Didn't drive her the remainder of the weekend so don't yet know if I have a real problem with the ignition or not! Key is just a few years old having replaced my very original that had worn down to the point that it was ok in the ignition, but wouldn't unlock a door!
