The other day, I turned off the truck and pulled the key out while still in drive. I was a bit alarmed as I started rolling backwards and realised what had happend. I thought this must be a fluke so I did it a couple more times to be sure. Sure enough, I can remove the key while in gear. Now I know this isn't normal as this was not possible to do on my last 80. I don't know why, maybe mudder subconcious at work
, I popped off the shift lock cover for a look see. Now I don't know what it should look like in there but my instincts said it doesn't look right. So I put her in park, igniton off, and tried to use a flat head screwdriver to pop the shift lock mechanism to no avail. It was as if there wasn't anything for the screwdriver to catch on/fit in. I could not get the shift lock to work. Maybe I'm barking up the wrong tree here but I thought I should post my thoughts.
Truck History
1997 LX 450 168K on the clock. Everything is well maintained and she runs like a top. The PO (Tarbe for those who know him) here on the board is the most OCD person I have ever seen when it comes to repairs, maintenance and PM. Tarbe never touched the shift lock mechanism as he never had the need to. I am the fourth owner so anything before Tarbe is lost.
So the question is, is this a potential problem? If it is, am I on the right track or could this be associated with a faulty ignition switch of sorts?
Thanks in advance for the help.
Buck Buchanan
, I popped off the shift lock cover for a look see. Now I don't know what it should look like in there but my instincts said it doesn't look right. So I put her in park, igniton off, and tried to use a flat head screwdriver to pop the shift lock mechanism to no avail. It was as if there wasn't anything for the screwdriver to catch on/fit in. I could not get the shift lock to work. Maybe I'm barking up the wrong tree here but I thought I should post my thoughts.Truck History
Buck Buchanan
