- Thread starter
- #21
richg said:Hey allstar, you might want to be somewhat informed about a topic before calling someone else thick headed.
If you don't have an existing master key, you cannot program new keys (be they master or sub). The only reason you were able to program a new key was because you already had an existing master key.
If you do not have a master key, you either have to get the ECM replaced, or have it flashed by a competent locksmith with the right equipment.
rich
Thanks richg, I am not trying to make a 'fiasco' out of this I am trying to make sure before I go and spend $$$ if I have a master. Sorry to have seemed to upset you...
Update: I believe that I will be OK with the broken end of what I believe was a master key. I ordered a new key today and will program it and have it cut around here. It should work. I'll post when I get it done.
and take a pill... there is really no reason to get so ticked off about any of this, right. Thanks for the input though I did end up buying a key but I also got a bypass after doing some research for my alarm system.
