Key no Worky
Ohio
I was getting in LC3 the other day and my key would not go into the ignition switch (1971 FJ40-original switch). I had to do alittle hotwire job in order to get home and I switched the ignition switch out with the one from LC2. When I look where the key goes, it doesn't look like anything is there; however, the key will still not go in. I have decided to try and replace the lock cylinder and see that SO$ has on available. I tried to get the lock cylinder out of the switch housing but it wouldn't budge and whenever I really torque on something-it usually turns out badly (like my hatch lock cylinder!) Any ideas how to get the lock cylinder out of the switch housing or has anyone bought the switch from SO$? I guess I could call them and see what all is included. Thanks.
Ignition on the column or the dash...
Column is servicable and will come out, if you can get the key in there to turn it... :)
Dash is not..AFAIK...
Replace with new.... Good idea,
Good luck!
-Steve
It's the dash mount. I also was just looking at the replacement switches on CCOT just now. I will also check at the local Toyota dealer and see how cooperative they are.
Yup. I was going to say the same thing. Got one for the '45 from Dan.
The dash mounted ignition switch is sold only as a complete assembly...
(have purchased at least ten in the last 16+ years) :)
Good luck!
-Steve
Ibid. (what he said :D ) Got a cool big old Toyota key with it, too.
