Key Fob help.
Lafayette, La
I searched the forums and from what I can reAd the ECU that you need the Fob traineed to is under thr drivers seat. I have nothing there. I do have an ild Fob that's working, but bought two clones when I received 2 new key. Thanks
Hindsight is 20/20.
No RS3000 black box under the seat, no need or use for fobs.
They were a pain compared to new alarms anyway.
I have a fob that works. Where is it sending in order to open the doors?
Your 80 buddy - you have to do the investigation yourself.
If your fob is a Toy one, the RS3000 is supposed to be under the LH seat.
Not to say some moved it, or tied into the lock trigger & relocated - we've 2 decades since these were built so all kinds & thoughts went into PO mods.
One of the times you simply need to spend quality time looking around your own 80. :meh:
Post up a picture of your FOB. You may have an aftermarket alarm. They are usually under the dash and look like a rats nest of wires that some low pay alarm installer did as fast as he could so he could go home.
Hey Footwork. Did you ever figure out your alarm system? I have an alarm module under the dash as well. Mine is probably not OEM but it was installed well and I've heard of some others that supposedly had port installled alarms under the dash. I have a blue LED in my dash. Well, the reason I'm asking is my fob doesn't seem to be working correctly and its causing my alarm to go off...pain in my ass. The module under my dash doesn't seem very programmer friendly and I'm wondering if you had similar issues as me. I have '91 80.
I have the port installed alarm, the one that is shared with all imports. I found two new Isuzu key fobs on eBay, programmed them by pushing the small green button on the unit under the seat, and held the unlock/lock button. I have better range with the new remotes now.
