Key fob - failed button replacement
North Dallas
The one and only key fob I received when I bought my LX450 never worked. The PO told me the alarm always acted weird so he just never used it. A while back I eventually got around to replacing the battery to give it a shot for myself and it did have some strange behaviors. When I pressed the button it would lock but a few seconds later it would unlock... sometimes. Very odd. About 2-3 days later the fob completely stopped working. After pondering I had a feeling the primary button was probably stuck in the depressed position which drained the battery dead. I don't believe the LED is working on the fob as I don't remember seeing it constantly on... its been a while. I really don't care about the LED, FYI.
I disassembled the fob today to examine the buttons and sure enough the microswitch button appears to have failed and is stuck in the depressed position.
I have been looking around the web trying to find a replacement microswitch which isn't as easy as it sounds not knowing the part number of the switch. My best guess is probably the one in the link below.
https://smile.amazon.com/Uxcell-a12011500ux0296-Momentary-Tactile-Surface/dp/B008DS1FQO/?tag=ihco-20
Based on my measurement of the microswitch it appears to be a 5x5mm wide part which matches the description of the amazon part(s).
I am really not super enthused about buying 100 of these damn things for $12.46 but it is cheaper than a crappy replacement fob ($21.45) which I still ponder.
https://smile.amazon.com/dp/B013TGJM2I/?tag=ihco-20
I am not sure anyone would know the answers to the questions I have but I figured I would give it a shot.
- Has anyone done this repair before?
- Does anyone know any detailed information about the microswitch part?
- Does anyone have a schematic of the FOB that might have a part number?
- If I simply removed the primary button from the board, could I re-pair the fob using the bottom button and be good to go?
Any help anyone could provide would be appreciated!
Here is how i fixed mine with the same issue. mine you could not see any or feel the button moving when pressed (it felt to be permanently bottomed out).
You have the board out. put it in a container with 99% isopropyl alcohol and let it sit for a few hours or over night/day... anyway you get the idea let it sit in that stuff.
Then I took an old electric toothbrush ( I no longer use for my teeth) and removed the brush end just leaving the metal shaft that vibrates/rocks back and forth. I stuck that in and let it vibrate on the button while in the alcohol. I saw a lot of stuff that appeared to be coke coming out but after that some green... like from copper green. I did that for about 20 seconds then changed the alcohol out and tried another 20 seconds and even more stuff came out. then when i was done the button would very easily click from depressed to pressed when i applied pressure.
now it works fine. I also added another fob that is after market from ebay or amazon.. I don't remember but it works also and now i have two.
good luck!
