Key cylinder lamp
fort smith, arkansas
I’ve used the bulb compilation and didn’t see anything. I’ve been scouring the parts drawings and I can’t find a part number separate from the lamp assembly. The bulbs is similar to a type 74, but I’m here to tell you an autozone sylvania type 74 won’t work. The oem bulb has a sort of bend on the wires at the bulb base to click it into the socket. Anyways, any gurus thing they can come up with a PN for the bulb w/green condom on the tip?
I’m going to post up the answer to my own question since I kept digging and found it in the drawing. It’s actually two part numbers, one for the bulb and one for the green “cap” that goes over its.
Bulb
90981-11014
Cap
84998-10070
Hopefully this will help someone trying to get the oem part down the road.
3rd column from the end has PN, just not toyota ones ;)
why would someone elses after market PN be relevant or useful to a toyota thread asking for oem part number? i dont mean to sound rude, it just isnt a useful post. it also lists the ring illuminator as blue, which is also wrong. thanks though, i guess.
I have factory Lexus incandescent lights on our two LXs, and a SuperBrightLED (green) LED in my son’s 00 LC, and really haven’t noticed a performance difference between the two. Can you elaborate on how the OE bulb outperforms the aftermarket?
not a matter of performance, was an issue of fitment. i purchased a pack of generic sylvania type 74 bulbs to replace the burnt oem one. at first glance, the aftermarket is a bigger bulb, but the base is the same size so it shouldnt matter. however, the oem bulb filament has a sort of design to it on the outside of the base of the bulb that allows it to fit firmly into place in the socket. the after market bulb did not have this and would not stay in the socket, just fell out when i tried to put it all back together. further more, the physical size differance did make it difficult to fit into the space provided in the ring assembly. look, this probablly not an issue for 99% of the bulbs in the truck, and it may only be the case for sylvania brand type 74 bulbs, but it doesnt work in the ignition key assembly, which is what started my quest for the oem bulb. anyways i have the bulb and the cap on the way. ill post side by side comparison of the bulbs when it arrives that may help shed light on the differences.
