Kelford Cams?
Houston, TX
I am considering Kelford's Stage-1 cams (225-A) for my engine rebuild. Before I order them, I want to be sure that they will work with OEM Lifters and shims. I asked Kelford this question a while back and have not received an answer, which seems a little odd. I see Kelford mentioned here and there in the 80-series forum, but has anyone actually installed them that might know the answer to this question?
Also, I will be using Ferrea valves and associated parts. The original plan was to use Ferrea springs, but Kelford recommended their springs over Ferrea. I asked a similar question that has not been answered, will the Kelford springs work with OEM spring seats and retainers. Might someone here know the answer to this question?
Why that route instead of all OEM?
Kelford advised me that stage 1 cams will be fine with factory valve springs. If you really want to go this route make sure you get an aftermarket ecu to utilize these camshafts. If not just stick with OEM camshafts.
