Landpimp said:I just took off the 35" MTR's on my 45LPB, went back to 33x9.5's........damn its SO much nicer. but oddly it harder to turn(no PS) when stoped wiht the 33x9.5's then the 35x12.5's.
lowtideride said:is a stock tire a 29? or a 27?
Odo and speedo will be off by the exact same amount if calibrated properly. One is driven off of the otherdogboy2 said:you are most likely about 10% off on your odometer readings and about 15% off on your speedometer readings with the 33's vs. stock diameter. you will be traveling faster/farther than your gauges read.
learned of this when I had a speedo correction gear installed on our '60 with 33x10.5's BFG AT/KO's
hth,
-dogboy- '87 FJ60
