Just removed Eibach rear spring perches
Holly Hill South Carolina
Replaced lower rear spring perches with Ironman 4x4 adjustable spring perches and super bump stops inside Ironman coils.
Raised rear another inch.
Now my rear fender wells are at 41 inches off the floor through the center axle line.
They were d.s. 39 1/2 and p.s. 40 even.
I set d.s. at 7/16 higher than p.s. with p.s. at lowest setting.
I kept the Eibach top mounts in place because the Ironman bump stops slipped right over them. The springs can't get free because the shocks and sway bar links (to a lesser degree) prevent it.
I had to use spring compressors to get springs in. These are the Ironman 880 lbs additional weight springs.
That panhard bar sits at pretty steep angle. A PCK would help help a lot in this case.
