Just another header thread
North Pole, Alaska
This past week I responeded to a thread about headers. I see that some of you have the same problem as I do. Constantly having to tighten header bolt and dealing with leaks. I went to Eastwood and Summit and got some part numbers. I plan to try the split lock kit this summer.
Have any of you tried copper header and collector gaskets? If so are they worth the money. I am to the point I will try almost anything.
SBC Locking Header Bolt Kit 3/8"-16 x 3/4" item# 46162 (Eastwood)
Split Lock Headre Bolts item# BPP-200-101 (Summit) these are spendy.
Lashcat,
I can't speak to V8 headers, but the priciples , I think are the same. Use a good quality gasket and torque to the upper limits of the recommended torque range. Start the motor and let it warm up to operating temp. Let it cool down and retorque. Run it for an hour and repeat. Then longer and longer repeating the retorque. Do it again and again until the torque dosen't change.
If you allow exhaust gasses to breach the gasket, you are fawked. So, a little time spent in the first few hours of your install will pay off. That is...all things remaining equal, you know like mating surfaces are true, etc.
That's all I know.
GL
Ed
