jump seats
Texas
boy it's sure hard to find reasonable, decent jump seats. Is there anyone out there that has a fab shop who could make aftermarket ones? Maybe use square tubing?
It amazes me how much trashy ones cost.
anyone?
Yea! Man..treasures... like gold...
I've made some late model ones, but it's barely worth the effort. I had two or three with the bottom broken off, so I made the folding bottom part, along with the legs. Still need upholstery, paint, and all, so you're not too far ahead. I had the hoops bent in the proper material (actually a little heavier), wasn't cheap. Then you still need to fab the flat metal parts, build the leg brackets, seat strap, etc etc. Wouldn't be worthwhile to me unless I was gonna do a whole bunch.
i took my early model ones that had shot covers and cut them down re-adjusted the hinge placement then welded them back together so they are now the same demensions as the late model jumpers. I then got a set of new seat covers and cut some foam to fit. worked perfect. It probably took about 4 hours. Even if you dont ahve the early jump seats on hand you can usually get them for alot cheaper b/c every one wants the late model ones they can fit inside the oem or metal tech replica cages.
Jim
keep looking I saw some on the JDM for sale that were given away I believe. they are out there.
