This is not intended to be the end all do all repair for FJ40 Jump Seat Frames. In the USA with the shop, tools and resources available to me I would have done this differently. However, here in Ecuador I have much more limited access to good used parts and resources as well. So perhaps some of the younger fellows who have a significant other who frequently reminds them of how much money they are spending on their FJ40 might glean some useful information from this repair on the cheap.
Once the covers were removed, revealing the original horse hair padding, I saw that the lower horizontal piece on the back rest frames as well as the hinge end horizontal on the seat frames were badly rusted. Also noted that the hinge on the seat frames had been "repaired" and poorly at that. So I purchased two lengths of steel tubing to effect repairs. Only available in 6 meter lengths I bought one that was one inch O.D. and the other was 7/8" O.D. and just slips inside the larger one. This would allow me to cut back to good parent material, slip a length of tubing in and then slip the full size piece into place and provide something to weld to and strengthen the joint. Since I had so much I slipped a length inside the new long tubes to provide additional wall strength for the screws that will secure the new upholstery. Reclaiming the hinges themselves was a challenge. Since they have the correct radius for mating to the parent tube I wanted to maintain that. I will look tomorrow for either clevis pins or 10mm bolts with no thread near the head from which to fabricate a clevis pin to replace the rivets that I removed.
