RockCrawler.com Jeep Wrangler JK Steering Stabilizer & Bracket
OLD MAN EMU STEERING STABILIZER: As another integral component of Old Man Emu’s four-wheel drive suspension range, steering stabilizers are*designed to reduce the effect of wheel vibration and improve the feel, handling and control of the vehicle. They*will also reduce the aggressive rotation of the steering wheel over rough roads without affecting steering wheel*return. DESIGN [...]Jeep Wrangler JK Steering Stabilizer & Bracket is a post from: RockCrawler 4x4 and Offroad Magazine
DESIGN & DEVELOPMENT:
After on-board and dyno testing the Old Man Emu engineering team have developed a steering stabilizer/damper with*increased compression and extension damping performance. This improved performance will assist in the overall ride*and control of the JK Wrangler. To provide clearance from other factory suspension components Old Man Emu have*utilized a rubber dust boot instead of the traditional steel guard. The OMESD48 steering stabilizer comes with a fitting*kit to suit both left and right hand drive applications. A benefit for left hand drive vehicles is that the stabilizer can be*mounted above the tie rod, giving it greater protection in serious off road situations.
FEATURES:
• 9 stage coil spring valving: for optimum performance
• 14mm piston rod: stronger than the original
• Rubber dust boot: protects the piston rod against stone damage
• 35mm piston and bore: increased oil volume
• Twin tube design: protects the internal components against stone damage
• Multi lip seal: prevents oil loss
• Original mounts: for ease of installation original stabilizer mounts are used where appropriate
• Includes fitting instructions P/N 3787933
RELOCATION FITTING KIT:
For all LHD Jeep Wrangler JKs, a steering stabilizer fit kit (P/No. FK50) is required to relocate the stabilizer above*the tie rod. By repositioning, this ensures the stabilizer is less vulnerable to damage as it is no longer the lowest*part of the front suspension.
APPLICATION GUIDE:
The ARB application guide has been update and available on ARB USA’s website at www.arbusa.com.
Link
